Siebel Object Interfaces Reference > Using Siebel Visual Basic and Siebel eScript > Configuring Error Handling > Calling More Than One Object Interface Method In a ScriptYou can call more than one object interface method in a script. To call more than one object interface method in a script Example of Calling More Than One Object Interface Method in Siebel VBThe following example uses the Select statement in Siebel VB: Dim iReturn As Integer Example of Calling More Than One Object Interface Method in Siebel eScriptThe following example is in Siebel eScript: var iReturn; |
| Siebel Object Interfaces Reference | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
