Siebel Database Upgrade Guide for DB2 for z/OS > Reviewing the Siebel Upgrade Log Files > Viewing the Siebel Job Log StatusEnvironments: All environments. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. Whether you are using Siebel-scheduling or vendor-scheduling to run your upgrade jobs, you can query the Siebel job log for the staging and target upgrade processes by completing the following procedure. NOTE: To view job status, you must have installed DSN REXX. To view the Siebel job log status
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
