| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Siebel Database Upgrade Guide for DB2 for z/OS > Generating the Siebel Upgrade Files > Preparing and Executing the Nonadditive Schema and JCL Files on the z/OS Host > Transferring the Nonadditive Schema, Temp Table, and Load and Unload Files to the z/OS HostUse the following procedure to transfer the nonadditive schema DDL files, the Temp table DDL files, and the Load and Unload control cards generated by the Upgrade Wizard on the midtier up to Pause #2 to the z/OS host. NOTE: Edit the generated files as required by Siebel Technical Notes, Siebel Alerts and Siebel Release Notes on My Oracle Support, or other publications before transferring them to the z/OS host. To transfer the files generated on the midtier
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
