Siebel Database Upgrade Guide for DB2 for z/OS > About Siebel Database Upgrade Topics >
Naming Conventions Used in This Guide
This guide follows several naming conventions:
- DB2 or DB2 for z/OS refers to IBM DB2 UDB for z/OS.
- Current release means the currently shipping release of the Siebel Business Applications provided by Oracle.
- Siebel CRM Release 7.x refers collectively to all versions of Siebel CRM Release 7 (SIA) from which you can upgrade directly to Siebel CRM version 8.1 (7.5.3, 7.7, or 7.8.2) or to Siebel CRM version 8.2 (7.8.2).
NOTE: Siebel CRM Release 7.x does not refer to versions of Siebel CRM earlier than version 7.5.3. You cannot upgrade directly from pre-7.5.3 versions of Siebel CRM to Siebel CRM version 8.1 or 8.2.
- The term Windows refers to all Microsoft Windows operating systems listed as supported for this release on the Certifications tab on My Oracle Support.
- The term UNIX refers to all forms of the UNIX operating system listed as supported for this release on the Certifications tab on My Oracle Support. UNIX is a Siebel Enterprise Server software platform.
NOTE: Linux is treated in this guide as a UNIX operating system. Specific supported Linux operating systems are listed on the Certifications tab on My Oracle Support.
- The term IBM z/OS refers to all the IBM mainframe operating systems, collectively referred to as z/OS, which are supported for this release as described on the Certifications tab on My Oracle Support. The z/OS operating system is a Siebel database software platform.
