Siebel Database Upgrade Guide for DB2 for z/OS > Performing the Siebel Incremental Repository Merge > About the Siebel Incremental Repository MergeIf you are upgrading from Siebel CRM version 8.1.1.x (SIA repository) to Siebel CRM version 8.1.1.14, you perform an incremental merge of the Siebel database. Performing an incremental repository merge is required if you intend to use the new features included in the Siebel CRM version 8.1.1.14 Innovation Pack. NOTE: On the DB2 for z/OS platform, incremental repository merge functionality is not supported for upgrades to Siebel Release 8.2. The process of performing an incremental repository merge is described in detail in Siebel Database Upgrade Guide. This chapter describes tasks that are specific to the z/OS platform. Where necessary, you are directed to Siebel Database Upgrade Guide for information on tasks that are common to all database platforms. |
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
