| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Siebel Database Upgrade Guide for DB2 for z/OS > Planning a Siebel Database Upgrade > Planning Backup and Recovery StagesIn addition to the backup and recovery procedures that are standard for your environment, take a set of DB2 backups at key stages during the upgrade, using your preferred utility. A snapshot of your repositories and environment at these stages protects the progress of your upgrade in the event of a failed subsequent process. It is recommended that you back up your Siebel schema at these key stages of the upgrade:
 Review the results of all JCL jobs that you execute during the install or upgrade process. You can use a spool viewer such as IBM's SDSF to inspect the output from these jobs. You can review this information in addition to reviewing the upgrade log files.  |
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
