Siebel Database Upgrade Guide for DB2 for z/OS > Planning a Siebel Database Upgrade >
Obtaining Required Software and Hardware
Because each enterprise has specific requirements for hardware and software resources, it is recommended that you discuss your particular situation with your Siebel technical resource. Make sure your hardware supports the requirements of your Siebel CRM upgrade. To verify that your computer, operating system platforms, and third-party programs are supported for the current release of Siebel CRM, see the Certifications tab on My Oracle Support (https://support.oracle.com).
