Siebel Database Upgrade Guide for DB2 for z/OS > Postupgrade Tasks for Siebel Database and File System >
Regenerating the Database Template File
Upgrades: All upgrades. Environments: Development environment only. Following the upgrade, you must regenerate the SQL Anywhere database template file used by Siebel Remote. Use the Generate New Database Component from a New Siebel Server option to do this. For procedures on regenerating the SQL Anywhere Template file, refer to Siebel Remote and Replication Manager Administration Guide.
