Siebel Database Upgrade Guide for DB2 for z/OS > Performing Postupgrade Tasks on the Target Database > Deleting Redundant Upgrade FilesEnvironments: All environments. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. After you complete the database upgrade process, delete any upgrade files that are no longer required. The procedures in this topic describe how to drop all staging database objects, and how to delete Unload data sets and stored procedures. Removing the Staging DatabaseAfter you have successfully completed your database upgrade, you must remove the staging database objects before you can reuse the same database prefix and tableowner name. To remove the staging database
Deleting Unload Data SetsWhen your database upgrade is completed, you no longer require the Unload data sets. Perform the following procedure to generate a list of the Unload data sets and then delete them. NOTE: Before performing this procedure, you must have the *.siebel.exec library allocated.
Deleting Stored ProceduresA number of stored procedures are installed during the database upgrade on the z/OS host to facilitate upgrade processing. These stored procedures are not required after the upgrade has been completed successfully and can be deleted. The following procedure describes how to drop the upgrade stored procedures. For information on installing the stored procedures, see Creating and Deploying Stored Procedures on the Target Database. |
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
