Siebel Database Upgrade Guide for DB2 for z/OS > Preparing a Production Environment for a Siebel Upgrade > Preparing for a Siebel Upgrade Without a Development EnvironmentEnvironments: Production test, production. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. If your installation does not include a development environment, you do not have to merge your Siebel Repository. Instead, you can use the repository and schema definition files included in the Siebel Database installation. Before performing the upgrade, you must move and rename these files. To prepare for an upgrade without a development environment
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
