Siebel Database Upgrade Guide for DB2 for z/OS > Tuning the Siebel Production Upgrade Scripts > About Tuning the Upgrade ScriptsEnvironments: Production test environment only. Does not apply to production environment. You can tune the SQL upgrade scripts in a production test environment to improve their performance and then reuse these tested scripts in the live production environment. For example, the scripts used to upgrade your Siebel database are generic. They update your Siebel database to support all Siebel applications' functionality. You can reduce downtime by tuning these scripts to optimize performance by eliminating SQL statements that are not required. You can then reuse these revised scripts in your production upgrade. You can tune your production upgrade scripts at any time after upgrading the Siebel database schema in your production test environment. Contacting Oracle's Advanced Customer ServicesYou are required to contact your Oracle sales representative for Oracle Advanced Customer Services to request approval for any upgrade script tuning that you perform. If you do not, you might invalidate your support agreement. It is recommended (but not required) that you contact Oracle's Advanced Customer Services for help with the following tasks:
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
