Using Siebel Tools > Using Siebel Script Editors > Using the Siebel Debugger >
Setting Debug Options
This topic describes how to set debug options.
To set debug options
  1. In Siebel Tools, click the View menu, and then click Options.
  2. In the Development Tools Options dialog box, click the Debug tab, and then set the options.
    The following table includes example settings for the Debug tab. For more information, see Development Options for Debugging.
    Option
    Value
    Executable
    siebel.exe
    CFG File
    c:\siebel\bin\w32u\enu\uagent.cfg
    For more information, see Specifying the Data Source That Siebel Tools Uses.
    Working Directory
    c:\siebel\bin\w32u
    Arguments
    You can use the following arguments:
    • /h.
    • /l. Sets the language that Siebel Tools uses for the debug session.
    You can include these arguments on the same line and in any order. For example, you can use one of the following for ENU:
    • /h /l ENU
    • /l ENU /h
    User Name
    sadmin
    Password
    Data Source
    Sample
    Enable Profiler
    Contains a check mark.
  3. Click the Scripting tab.
  4. In the Debugging section, set the options, and then click OK.
    For more information, see Development Options for Visualization Views.
Using Siebel Tools Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices.
