Using Siebel Tools > Using Siebel Script Editors > Using the ST eScript Engine >
Setting Options for the ST eScript Engine
This topic describes how to set options for the ST eScript Engine. To set options for the ST eScript Engine
- Make sure the ST eScript Engine is enabled.
For more information, see Enabling the ST eScript Engine.
- In Siebel Tools, click the View menu, and then click Options.
- In the Development Tools Options dialog box, click the Scripting tab.
- To define the options in the Engine Settings section, use the information in the following table. It is recommended that you enable all of these options.
