Using Siebel Tools > Using Siebel Tools > Using Windows, Wizards, and Toolbars >
Using the Properties Window
The Properties window is a window that displays the properties and the property value for the object that you choose in the Object List Editor. It displays the name of this object near the top of the window. It displays the name of the property in the left column, and the property value in the right column. Siebel Tools displays properties in the Properties window in alphabetic order. You can click the Categorized tab to view these properties grouped according to category. The Properties window does not display the Project property or the Changed property.
In this example, you use the Properties window to modify the Comments property of the Siebel Call Center application.
To use the Properties window
  1. Locate the Siebel Call Center application in the Applications list.
    For more information, see Locating and Modifying Object Definitions in the Object List Editor.
  2. Click the View menu, Windows, and then click Properties Window.
  3. In the Properties window, enter the following text in the Comments property:
    I can modify values in the Properties window or in the Object List Editor.
  4. To verify your modifications, examine the Comments property in the Applications list. It includes the values you entered.
Using Siebel Tools Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices.
