Using Siebel Tools > Using Siebel Tools > Using Windows, Wizards, and Toolbars >
Using the Multi Value Property Window
The Multi Value Property Window allows you to view and set values for multi-value properties when you use one of the following designers:
- Entity Relationship Designer
- Task Designer
- Workflow Process Designer
For more information about multi-value properties and how to use the Multi Value Property Window, see Siebel Business Process Framework: Task UI Guide and Siebel Business Process Framework: Workflow Guide.
