Siebel VB Language Reference > Using Siebel VB > Guidelines for Using Siebel VB >
Other Guidelines
It is recommended that you apply the following guidelines when you use Siebel VB. For information about each of them, see the topic about guidelines for using Siebel VB and Siebel eScript in Siebel Object Interfaces Reference:
  • Declare your variables
  • Use a standard naming convention
  • Use a self-reference to identify the current object
  • Avoid nested If statements
  • Use a four-digit year
  • Apply multiple object interface methods to a single object
  • Write code that handles run-time errors
Siebel VB Language Reference Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices.
