Generating Source Codes Using the Source Code Work File (WSRW)
Purpose: You can create a CWSerenade source code using information from the Source Code Work Table (IXSRCE).
Once you create a source code work record, you can use the Work with Source Code Work File option to change, delete, or display source code work records and then transfer the records to the Source Code table.
When you transfer the source code records, the system validates each record in the Source Code Work table:
• If a source code work record contains any errors, the system flags the record with a status of E and includes the record on the Source Code Upload File Exception Report. You can correct source code work records that are in an error status by selecting OK on the Change Source Code Upload File Screen (1 of 2).
• If a source code work record does not contain any errors, the system transfers the record to the Source Code table and displays the record on the Source Code Upload File Processed Listing. See Working with Source Codes (WSRC).
Source code work table process: The following flowchart explains how the system creates a CWSerenade source code using information defined in the Source Code Work table.
Transferring data into the work table: The SQL database does not allow an empty (null) value in any field, so in order to populate the Source Code Work Table (IXSRCE) without error for fields that you do not want to populate in the created source code records, enter a zero (for a numeric field) or a space (for an alphanumeric field).
In this topic:
• Work with Source Code Upload File Screen
• Change Source Code Upload File Screen (1 of 2)
• Display Source Code Upload File Screen
• Source Code Upload File Processed Listing
• Source Code Upload File Exception Report
Purpose: This screen displays all of the records in the Source Code Work Table (IXSRCE). Use this screen to review, change, delete and transfer source code work records.
How to display this screen: Enter WSRW in the Fast path field at the top of any menu or select Work with Source Code Work File from a menu.
Field
Description
Source (Source code)
A unique, user-defined code to identify a segment of your customer base and to analyze sales. The source code drives marketing, forecasting, pricing, freight, and service charge information on an order. See Working with Source Codes (WSRC).
Alphanumeric, 9 positions; optional.
Description
The description of this source code.
Alphanumeric, 30 positions; optional.
Div (Division code)
A unique code for a profit center or area of financial reporting.
Alphanumeric, 2 positions; optional.
Promo (Promotional code)
A code to group source codes together. See Working with Promotion Values (WPRO).
Alphanumeric, 7 positions; optional.
Offer
The code for the catalog, space, or advertisement from which you accept orders. See Working with Offers (WOFR).
Alphanumeric, 3 positions; optional.
Status (Source code work file status)
A code used to indicate whether this source code work record contains an error.
Valid values are:
E = the source code work record contains an error.
blank = the source code work record does not contain an error.
Alphanumeric, 1 position; optional.
Instructions:
Select Process File to submit the transfer. A message indicates that the source code transfer has been submitted.
The job validates that:
• The value defined in the Source code field is unique for the company you are working in.
• The Company, Consumer/business, Freight method, House account code, Price method, Type, Description, Breakeven amount, Restricted, Display on O/E select, Division, and Offer fields contain information.
• The Consumer/business, Freight method, House account code, Price method, Type, Exclude service charge, Promotion pricing, Display on O/E select, Exclude from flexible option, Exclude promotion, Division, Promotion code, Offer, Source category, Freight table, Recency code, List source, FPO payment code, and Price table fields contain valid values.
If a record passes all of the edits performed, the system:
• prints the source code work record on the Source Code Upload File Processed Listing. This report lists all source codes created through the source code upload.
• creates a CWSerenade source code. You can review or maintain the source code in Working with Source Codes (WSRC).
• deletes the record from the Source Code Work table.
If a record does not pass all of the edits performed, the system:
• prints the source code work record on the Source Code Upload File Exception Report. This report lists all of the source code work records that contain errors.
• retains the source code work record in the Source Code Work table until the record is fixed or deleted. You can correct errors that exist on a source code work record on the Change Source Code Upload File Screen (1 of 2).
Screen Option
Procedure
Change a source code work record
Select Change for a source code work record to advance to the Change Source Code Upload File Screen (1 of 2).
Delete a source code work record
Select Delete for a source code work record to delete it.
Display a source code work record
Select Display for a source code work record to advance to the Display Source Code Upload File Screen.
Submit the upload process
Select Process File. See above.
Purpose: Use this screen to change information defined for a source code work record.
When you select OK on this screen, the system highlights any fields that are in error so that you can correct them. You cannot transfer a source code work record to the Source Code table if it contains any errors.
How to display this screen: On the Work with Source Code Upload File Screen, select Change for a source code work record.
See Create Source Code Screen (1 of 2) for a description of the fields on this screen.
Change Source Code Upload File (2 of 2)
How to display this screen: Select OK on the Change Source Code Upload File Screen (1 of 2).
How to display this screen: Select Display for a source code work record at the Work with Source Code Upload File Screen to advance to the Display Source Code Upload File screen. You cannot change any information on this screen. For field descriptions, see Create Source Code Screen (1 of 2).
Purpose: You can use the Work with Source Code Work File menu option to create source codes in your company based on the data in this table. See Generating Source Codes Using the Source Code Work File (WSRW).
Field
Attributes
Field Description
Company
Numeric, 3 positions; required
CWSerenade company. This is a key field.
Source code
Alphanumeric, 9 positions; required
CWSerenade source code. The source code must be a unique code within the Source Code table. This is a key field.
Consumer/business
Alphanumeric, 1 position; required
Valid values are:
B = business
C = consumer
Freight method
Alphanumeric, 2 positions; required
Valid values are:
$O = dollar chart/offer
$S = dollar chart/source
A = actual billing amount
F = flat rate/ship to
FI = flat rate/item
FQ = flat rate/quantity
FS = flat rate/item source
I = by item
OW = order weight
PS = percentage/source
PV = percentage/ship via
R = recipient
W = weight
House account code
Valid values are:
H = house account
blank = in-house list
Price method
Valid values are:
C = use item cost
D = regular plus reprice
N = no charge
O = no charge/no cost
P = regular hierarchy
Type
Valid values are:
N = do not analyze
K = known
U = unknown
Description
Alphanumeric, 30 positions; required
The source code description. This is a user defined field.
Breakeven amount
Numeric, 9 positions with a 2-place decimal; required
User defined field.
List broker code
User defined field.
List cost
User defined field.
Cover code
User defined field.
Discount %
Numeric, 5 positions with a 2-place decimal
User defined field.
Drop code
User defined field.
Exclude service
Valid values are:
N = no
Y = yes
blank = no value defined
Flat freight amount
Numeric, 7 positions with a 2-place decimal
User defined field.
Freight minimum
User defined field.
Freight maximum
User defined field.
Freight percent
User defined field.
Backorder priority
Numeric, 1 position
User defined field.
Gross circulation
Informational only.
Mail date
Numeric, 7 positions (CYYMDD format)
Marketing projection
User defined field.
Net circulation
Pop up window #1
User defined field.
Pop up window #2
User defined field.
Pop up window #3
User defined field.
Pop up window #4
User defined field.
Projected names
User defined field.
Requests mailed
Secondary freight
User defined field.
Up to freight quantity
User defined field.
Maximum ship tos-freight
User defined field.
Promo pricing
Valid values are:
N = no
Y = yes
blank
Restricted
Valid values are:
N = no
Y = yes
blank
Valid values are:
N = no
Y = yes
blank
% net fill
User defined field.
% margin
User defined field.
Cost per order
User defined field.
Variable ad expense
User defined field.
SRC user 1
User defined field.
SRC user 2
User defined field.
SRC user 3
User defined field.
SRC user 4
User defined field.
SRC user 5
User defined field.
SRC user 6
User defined field.
Exclude from flex opt
Valid values are:
N = no
Y = yes
blank
Exclude promotion
Valid values are:
N = no
Y = yes
blank
Division
Must be a valid CWSerenade division.
Promotion code
Must be a valid CWSerenade promotion code.
OFR number
Alphanumeric, 3 positions; required
Must be a valid CWSerenade offer number.
Source category
Must be a valid CWSerenade source category.
Ship via
Numeric, 2 positions
Freight table
Must be a valid CWSerenade freight table.
Recency code
Alphanumeric, 4 positions
Must be a valid CWSerenade recency code.
LST source
Must be a valid CWSerenade list source.
FPO payment code
Alphanumeric, 5 positions
Must be a valid CWSerenade FPO payment code.
Catalog request
Valid values are:
N = no
Y = yes
blank
Catalog request type
Must be a valid CWSerenade catalog request type.
Customer class
Must be a valid CWSerenade customer class.
Discount expiration
Numeric, 7 positions (CYYMMDD format)
Must be a valid date.
File status
Valid values are:
E = an error exists on this record.
blank = an error does not exist on this record.
Price table
Must be a valid CWSerenade price table.
Commission pct
Warranty required
Valid values are:
N = no
Y = yes
blank
Credit check?
Valid values are:
N = no
Y = yes
blank
WSRW Serenade 5.0 March 2015
