| Siebel CRM Application Deployment Manager Guide Siebel Innovation Pack 2015 E24721-01 |
![]() Previous |
![]() Next |
View PDF |
This topic contains data type attributes that you can use when adding new Siebel Application Deployment Manager (ADM) data types for deployment. This topic includes information for the following ADM data types:
Attributes for the Access Controlled Business Service database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Access Controlled Business Service data type attributes, see Table B-1. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-1 Attributes for the Access Controlled Business Service Database Data Type
| Data Type Attribute | Access Controlled Business Service |
Parent Data Type |
Not applicable |
Registry Parameters |
None |
Enterprise Profile Parameters |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Deploy Validation Method |
Method=CheckSchemaVersion |
Activate Method |
Business service=Access Controlled BS Cache Clear Service; Method=Activate |
Activate Validation Method |
Not applicable |
Steps Automated by Activate or Restore Activate Methods |
None |
Restore Method |
EAI |
Delete New Objects Parameter |
Yes |
Restore Activate Method |
Business service=Access Controlled BS Cache Clear Service; Method=RestoreActivate |
Restore Activate Validation Method |
Not applicable |
Max Units Per Package |
No limit |
Manual Steps |
User reconnect to see changes |
Additional Downtime Impact |
None |
Deployment Prerequisites |
None |
Notes |
None |
Attributes for the Access Controlled Task database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Access Controlled Task data type attributes, see Table B-2. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-2 Attributes for the Access Controlled Task Database Data Type
| Data Type Attribute | Access Controlled Task |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Business service=Access Controlled Task Cache Clear Service; Method=Activate |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Business service=Access Controlled Task Cache Clear Service; Method=RestoreActivate |
Not applicable |
No limit |
Manual Steps |
None |
None |
Notes |
None |
Attributes for the AccessGroup database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the AccessGroup data type attributes, see Table B-3. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-3 Attributes for the AccessGroup Database Data Type
| Data Type Attribute | AccessGroup |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the AccntPromo database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the AccntPromo data type attributes, see Table B-4. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-4 Attributes for the AccntPromo Database Data Type
| Data Type Attribute | AccntPromo |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the ADM Abs Admin Service Region database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ADM Abs Admin Service Region data type attributes, see Table B-5. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-5 Attributes for the ADM Abs Admin Service Region Database Data Type
| Data Type Attribute | ADM Abs Admin Service Region |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the ADM Abs Admin Time Window Map database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ADM Abs Admin Time Window Map data type attributes, see Table B-6. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-6 Attributes for the ADM Abs Admin Time Window Map Database Data Type
| Data Type Attribute | ADM Abs Admin Time Window Map |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the ADM Comm Inbound Group database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ADM Comm Inbound Group data type attributes, see Table B-7. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-7 Attributes for the ADM Comm Inbound Group Database Data Type
| Data Type Attribute | ADM Comm Inbound Group |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the ADM CommSrv CM Adapter Administration database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ADM CommSrv CM Adapter Administration data type attributes, see Table B-8. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-8 Attributes for the ADM CommSrv CM Adapter Administration Database Data Type
| Data Type Attribute | ADM CommSrv CM Adapter Administration |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the ADM Project database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ADM Project data type attributes, see Table B-9. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-9 Attributes for the ADM Project Database Data Type
| Data Type Attribute | ADM Project |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
All data types included in the exported project must exist on the target system. |
Notes |
None |
Attributes for the ADM Search Category Available Flds database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ADM Search Category Available Flds data type attributes, see Table B-10. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-10 Attributes for the ADM Search Category Available Flds Database Data Type
| Data Type Attribute | ADM Search Category Available Flds |
Parent Data Type |
ADM Search Parent Category |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
ADM, Workflow, and EAI components must be enabled on the target server. |
Notes |
None |
Attributes for the ADM Search Connector database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ADM Search Connector data type attributes, see Table B-11. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-11 Attributes for the ADM Search Connector Database Data Type
| Data Type Attribute | ADM Search Connector |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
Notes |
None |
Attributes for the ADM Search Engine database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ADM Search Engine data type attributes, see Table B-12. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-12 Attributes for the ADM Search Engine Database Data Type
| Data Type Attribute | ADM Search Engine |
Parent Data Type |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
Notes |
None |
Attributes for the ADM Search Parent Category database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ADM Search Parent Category data type attributes, see Table B-13. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-13 Attributes for the ADM Search Parent Category Database Data Type
| Data Type Attribute | ADM Search Parent Category |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
Notes |
None |
Attributes for the ADM Shift Exception database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ADM Shift Exception data type attributes, see Table B-14. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-14 Attributes for the ADM Shift Exception Database Data Type
| Data Type Attribute | ADM Shift Exception |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the ADM Shift Schedule database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ADM Shift Schedule data type attributes, see Table B-15. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-15 Attributes for the ADM Shift Schedule Database Data Type
| Data Type Attribute | ADM Shift Schedule |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the AggrDiscount database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the AggrDiscount data type attributes, see Table B-16. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-16 Attributes for the AggrDiscount Database Data Type
| Data Type Attribute | AggrDiscount |
Parent Data Type |
AggrDiscSeq |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Business service=ADM on Aggregate Discount; Method=Activate |
Not applicable |
Clear cache |
Restore Method |
EAI |
Yes |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the AggrDiscSeq database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the AggrDiscSeq data type attributes, see Table B-17. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-17 Attributes for the AggrDiscSeq Database Data Type
| Data Type Attribute | AggrDiscSeq |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Business service=ADM on Aggregate Discount Sequence; Method=Activate |
Not applicable |
Clear cache |
Restore Method |
EAI |
Yes |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the AssignGroup database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the AssignGroup data type attributes, see Table B-18. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-18 Attributes for the AssignGroup Database Data Type
| Data Type Attribute | AssignGroup |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
Click the Release button in the UI for the changes to be effective. |
None |
None |
Notes |
None |
Attributes for the AssignRule database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the AssignRule data type attributes, see Table B-19. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-19 Attributes for the AssignRule Database Data Type
| Data Type Attribute | AssignRule |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
Notes |
This data type requires activation. |
Attributes for the AttrAdjustments database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the AttrAdjustments data type attributes, see Table B-20. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-20 Attributes for the AttrAdjustments Database Data Type
| Data Type Attribute | AttrAdjustments |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Business service=ADM on Attribute Adjustments; Method=Activate |
Not applicable |
Clear cache |
Restore Method |
EAI |
Yes |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Audit Trail Admin database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Audit Trail Admin data type attributes, see Table B-21. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-21 Attributes for the Audit Trail Admin Database Data Type
| Data Type Attribute | Audit Trail Admin |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Business service=Audit Trail Configuration Service; Method=UpdateAuditCache |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Business Rule database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Business Rule data type attributes, see Table B-22. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-22 Attributes for the Business Rule Database Data Type
| Data Type Attribute | Business Rule |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
Business service=Rule Runtime Administration; Method=Backup |
Deploy Method |
Business service=Rule Runtime Administration; Method=Deployment |
Not applicable |
Activate Method |
Business service=Rule Runtime Administration; Method=Activate |
Not applicable |
None |
Restore Method |
Business service=Rule Runtime Administration; Method=Restore |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Content Fixup database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Content Fixup data type attributes, see Table B-23. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-23 Attributes for the Content Fixup Database Data Type
| Data Type Attribute | Content Fixup |
Parent Data Type |
Symbolic URL |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Correspondence Template database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Correspondence Template data type attributes, see Table B-24. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-24 Attributes for the Correspondence Template Database Data Type
| Data Type Attribute | Correspondence Template |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
BusinessService=ADM Service; MethodName=start |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the CostList database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the CostList data type attributes, see Table B-25. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-25 Attributes for the CostList Database Data Type
| Data Type Attribute | CostList |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the DataMapObject database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the DataMapObject data type attributes, see Table B-26. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-26 Attributes for the DataMapObject Database Data Type
| Data Type Attribute | DataMapObject |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Discount and EC Matrix database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Discount and EC Matrix data type attributes, see Table B-27. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-27 Attributes for the Discount and EC Matrix Database Data Type
| Data Type Attribute | Discount and EC Matrix |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Business service=ADM on Discount and E&C Matrix; Method=Activate |
Not applicable |
Clear cache |
Restore Method |
EAI |
Yes |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the EAI Data Map database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the EAI Data Map data type attributes, see Table B-28. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-28 Attributes for the EAI Data Map Database Data Type
| Data Type Attribute | EAI Data Map |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Business service=EAI Data Transformation Engine; Method=Purge |
Not applicable |
Clear cache |
Restore Method |
EAI |
Yes |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the EAI Dispatch Service Rule Set database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the EAI Dispatch Service Rule Set data type attributes, see Table B-29. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-29 Attributes for the EAI Dispatch Service Rule Set Database Data Type
| Data Type Attribute | EAI Dispatch Service Rule Set |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Business service=EAI Dispatch Service Rule Set - ADM; Method=Activate |
Not applicable |
Clear cache |
Restore Method |
EAI |
Yes |
Business service=EAI Dispatch Service Rule Set - ADM; Method=RestoreActivate |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the ExpLOV database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ExpLOV data type attributes, see Table B-30. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-30 Attributes for the ExpLOV Database Data Type
| Data Type Attribute | ExpLOV |
Parent Data Type |
ExpType |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Business service=LOV Cache Clear Service; Method=Activate |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Business service=LOV Cache Clear Service; Method=RestoreActivate |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the ExpType database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ExpType data type attributes, see Table B-31. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-31 Attributes for the ExpType Database Data Type
| Data Type Attribute | ExpType |
Parent Data Type |
ExpType |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Fund database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Fund data type attributes, see Table B-32. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-32 Attributes for the Fund Database Data Type
| Data Type Attribute | Fund |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Host Table database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Host Table data type attributes, see Table B-33. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-33 Attributes for the Host Table Database Data Type
| Data Type Attribute | Host Table |
Parent Data Type |
Symbolic URL |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the iHelp database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the iHelp data type attributes, see Table B-34. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-34 Attributes for the iHelp Database Data Type
| Data Type Attribute | iHelp |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Business service=Task Import/Export; Method=Activate |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Business service=Task Import/Export; Method=RestoreActivate |
Not applicable |
No limit |
Manual Steps |
Click the Activate button in the UI to activate this data type. |
None |
None |
Notes |
None |
Attributes for the iHelp - Header database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the iHelp - Header data type attributes, see Table B-35. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-35 Attributes for the iHelp - Header Database Data Type
| Data Type Attribute | iHelp - Header |
Parent Data Type |
iHelp |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the JointWorkspace (Workspace Projects) database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the JointWorkspace data type attributes, see Table B-36. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-36 Attributes for the JointWorkspace Database Data Type
| Data Type Attribute | JointWorkspace (Workspace Projects) |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
Not applicable |
Deploy Method |
Business service=ISS Authoring Import Export Service; Method=ADMImport |
Not applicable |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
Not applicable |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
Click the Release New Version or Release All button in the UI. |
None |
None |
Notes |
None |
Attributes for the LOV (List of Values) database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the LOV data type attributes, see Table B-37. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-37 Attributes for the LOV Database Data Type
| Data Type Attribute | LOV (List of Values) |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
No limit |
Manual Steps |
None |
None |
Notes |
None |
Attributes for the MessageType database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the MessageType data type attributes, see Table B-38. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-38 Attributes for the MessageType Database Data Type
| Data Type Attribute | MessageType |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Business service=ADM on Message Type; Method=Activate |
Not applicable |
Clear cache |
Restore Method |
EAI |
Yes |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the PDQ (Predefined Query) database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the PDQ data type attributes, see Table B-39. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-39 Attributes for the PDQ Database Data Type
| Data Type Attribute | PDQ (Predefined Query) |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Personalization - Actions database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Personalization - Actions data type attributes, see Table B-40. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-40 Attributes for the Personalization - Actions Database Data Type
| Data Type Attribute | Personalization - Actions |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
For information about the behavior of this data type during deployment, see "Personalization - Actions". |
Attributes for the Personalization - Applets database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Personalization - Applets data type attributes, see Table B-41. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-41 Attributes for the Personalization - Applets Database Data Type
| Data Type Attribute | Personalization - Applets |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Business service=CT ADM Service; Method=Activate |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Business service=CT ADM Service; Method=RestoreActivate |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Personalization - Event Defs database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Personalization - Event Defs data type attributes, see Table B-42. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-42 Attributes for the Personalization - Event Defs Database Data Type
| Data Type Attribute | Personalization - Event Defs |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
For information about the behavior of this data type during deployment, see "Personalization - Event Defs". |
Attributes for the Personalization - Events database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Personalization - Events data type attributes, see Table B-43. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-43 Attributes for the Personalization - Events Database Data Type
| Data Type Attribute | Personalization - Events |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Personalization - Rules database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Personalization - Rules data type attributes, see Table B-44. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-44 Attributes for the Personalization - Rules Database Data Type
| Data Type Attribute | Personalization - Rules |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
For information about the behavior of this data type during deployment, see "Personalization - Rules". |
Attributes for the Personalization - Views database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Personalization - Views data type attributes, see Table B-45. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-45 Attributes for the Personalization - Views Database Data Type
| Data Type Attribute | Personalization - Views |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the PriceList database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the PriceList data type attributes, see Table B-46. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-46 Attributes for the PriceList Database Data Type
| Data Type Attribute | PriceList |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Business service=ADM on Price List; Method=Activate |
Not applicable |
Clear cache |
Restore Method |
EAI |
Yes |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the ProdFeature database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ProdFeature data type attributes, see Table B-47. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-47 Attributes for the ProdFeature Database Data Type
| Data Type Attribute | ProdFeature |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the ProdLine database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ProdLine data type attributes, see Table B-48. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-48 Attributes for the ProdLine Database Data Type
| Data Type Attribute | ProdLine |
Parent Data Type |
ProdFeature |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the ProductCatalog database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ProductCatalog data type attributes, see Table B-49. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-49 Attributes for the ProductCatalog Database Data Type
| Data Type Attribute | ProductCatalog |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the ProductData database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the ProductData data type attributes, see Table B-50. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-50 Attributes for the ProductData Database Data Type
| Data Type Attribute | ProductData |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
ProductData can only be updated. It cannot be inserted. |
Attributes for the Promotion database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Promotion data type attributes, see Table B-51. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-51 Attributes for the Promotion Database Data Type
| Data Type Attribute | Promotion |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Proposal Template database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Proposal Template data type attributes, see Table B-52. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-52 Attributes for the Proposal Template Database Data Type
| Data Type Attribute | Proposal Template |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Responsibility database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Responsibility data type attributes, see Table B-53. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-53 Attributes for the Responsibility Database Data Type
| Data Type Attribute | Responsibility |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the SmartScript database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the SmartScript data type attributes, see Table B-54. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-54 Attributes for the SmartScript Database Data Type
| Data Type Attribute | SmartScript |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
Business service=SmartScriptADM; Method=Backup |
Deploy Method |
Business service=SmartScriptADM; Method=Deploy |
Activate Method |
Business service=SmartScriptADM; Method=Activate |
Not applicable |
Activates the SmartScripts in the SmartScript administration. These SmartScripts are then available in the player for users. |
Restore Method |
Business service=SmartScriptADM; Method=Restore |
Yes |
Business service=SmartScriptADM; Method=RestoreActivate |
Not applicable |
1 |
Manual Steps |
None |
None |
None |
Notes |
For information about validating SmartScripts, see "SmartScript". |
Attributes for the StateModel database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the StateModel data type attributes, see Table B-55. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-55 Attributes for the StateModel Database Data Type
| Data Type Attribute | StateModel |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Symbolic URL database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Symbolic URL data type attributes, see Table B-56. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-56 Attributes for the Symbolic URL Database Data Type
| Data Type Attribute | Symbolic URL |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the UIThemeMapping database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the UIThemeMapping data type attributes, see Table B-57. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-57 Attributes for the UIThemeMapping Database Data Type
| Data Type Attribute | UIThemeMapping |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the UserList database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the UserList data type attributes, see Table B-58. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-58 Attributes for the UserList Database Data Type
| Data Type Attribute | UserList |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
After User Lists are imported by ADM, user visibility may be changed. User List is related to Catalog and Category, which are used for visibility control for some objects. Changes in User List may affect Catalog-based object visibility. |
Attributes for the View database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the View data type attributes, see Table B-59. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-59 Attributes for the View Database Data Type
| Data Type Attribute | View |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the VolumeDiscount database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the VolumeDiscount data type attributes, see Table B-60. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-60 Attributes for the VolumeDiscount Database Data Type
| Data Type Attribute | VolumeDiscount |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Business service=ADM on Volume Discount; Method=Activate |
Not applicable |
Clear cache |
Restore Method |
EAI |
Yes |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Web Application database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Web Application data type attributes, see Table B-61. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-61 Attributes for the Web Application Database Data Type
| Data Type Attribute | Web Application |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Web Service - Inbound database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Web Service - Inbound data type attributes, see Table B-62. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-62 Attributes for the Web Service - Inbound Database Data Type
| Data Type Attribute | Web Service - Inbound |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Business service=Web Service - ADM; Method=Activate |
Not applicable |
Clear cache |
Restore Method |
EAI |
Yes |
Business service=Web Service - ADM; Method=RestoreActivate |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Web Service - Outbound database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Web Service - Outbound data type attributes, see Table B-63. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-63 Attributes for the Web Service - Outbound Database Data Type
| Data Type Attribute | Web Service - Outbound |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Clear cache |
Restore Method |
EAI |
Yes |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Workflow Action Type database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Workflow Action Type data type attributes, see Table B-64. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-64 Attributes for the Workflow Action Type Database Data Type
| Data Type Attribute | Workflow Action Type |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Workflow Group database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Workflow Group data type attributes, see Table B-65. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-65 Attributes for the Workflow Group Database Data Type
| Data Type Attribute | Workflow Group |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Business service=Siebel Tools Deployment Support for ADM; Method=Activate |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
None |
None |
None |
Notes |
None |
Attributes for the Workflow Policy database data type can be used toward adding new Application Deployment Manager (ADM) data types for deployment. For a list of the Workflow Policy data type attributes, see Table B-66. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-66 Attributes for the Workflow Policy Database Data Type
| Data Type Attribute | Workflow Policy |
Parent Data Type |
Not applicable |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
Regenerate triggers and restart Workflow Monitor and Action agents. |
None |
None |
Notes |
None |
Attributes for the Workload Rule database data type can be used toward adding data types for deployment using Oracle's Siebel Application Deployment Manager (ADM). For a list of the Workload Rule data type attributes, see Table B-67. For more information about this data type, see Appendix A, "Siebel ADM Supported Data Types."
Table B-67 Attributes for the Workload Rule Database Data Type
| Data Type Attribute | Workload Rule |
Parent Data Type |
AssignRule |
None |
None |
Backup Method |
EAI |
Deploy Method |
EAI |
Activate Method |
Not applicable |
Not applicable |
None |
Restore Method |
EAI |
Yes |
Not applicable |
Not applicable |
No limit |
Manual Steps |
Click Release button in UI to make the changes effective. |
None |
None |
Notes |
None |
