| Siebel CRM Application Deployment Manager Guide Siebel Innovation Pack 2015 E24721-01 |
![]() Previous |
![]() Next |
View PDF |
Siebel Business Applications provide several data migration tools, including Siebel Application Deployment Manager (ADM), to migrate data based on the business scenario and volume of data to be migrated.
ADM is designed to migrate application customizations to same-version and same-language environments. For more information about this feature, see Chapter 4, "Migrating Customizations Using Siebel ADM."
Note: You can migrate data between environments of different languages if no language is specified for the data being deployed. |
ADM cannot be substituted for the specialized operations performed by using some of the other Siebel Business Applications migration or deployment tools:
Siebel EAI is used for migrating small volumes of data for mostly daily or weekly changes. The ADM framework is built on Siebel EAI. For more information about Siebel EAI, see Overview: Siebel Enterprise Application Integration.
Siebel EIM is used for migrating bulk data between databases using migration tables and is used for mostly large volumes. For more information about Siebel EIM, see Siebel Enterprise Integration Manager Administration Guide.
The repository migration option in the Siebel Database Configuration Wizard is used for migrating repository data and schema changes and is designed for large volumes. For more information about repository migration, see Using Siebel Tools.
