| Siebel CRM Application Deployment Manager Guide Siebel Innovation Pack 2015 E24721-01 |
![]() Previous |
![]() Next |
View PDF |
Review the following guidelines and recommendations when managing your Siebel Application Deployment Manager (ADM) package content:
Follow the documented naming conventions throughout the ADM deployment process:
During the creation of the ADM project
When storing the exported database files in directories
When storing files in directories with versions or tracked through a version tracking system
Follow a documented deployment strategy including procedures, checklists, and naming conventions.
Create the ADM package folder structure using the ADM Packaging Utility rather than creating it manually.
Use a stored file system or document tracking system when creating deployment units involves teams of users to make sure the package content is current and correct.
Validate packages before deployment.
