| Siebel CRM Application Deployment Manager Guide Siebel Innovation Pack 2015 E24721-01 |
![]() Previous |
![]() Next |
View PDF |
Where you will migrate customizations using Siebel ADM packages, the process of creating a Siebel Application Deployment Manager (ADM) package is the first phase in migrating application customizations to a new environment.For more information about the overall migration process, see Chapter 2, "Overview of Siebel Application Deployment Manager."
"Reviewing the Siebel ADM Data Type Requirements"
This task helps you determine how to package the application customizations.
"Consolidating Siebel ADM Data Types into Deployment Units"
This task consolidates the application customizations in a format that can be packaged.
