| Siebel CRM Application Deployment Manager Guide Siebel Innovation Pack 2015 E24721-01  |
![]() Previous  |
![]() Next  |
View PDF |
The following options for deploying Siebel Application Deployment Manager (ADM) customizations are available for database data type customizations only. They represent the ADM deployment methods available in earlier releases of Siebel Business Applications (for example, in Siebel CRM version 7.8):
"About Deploying Customizations Using Export Files and the ADM GUI"
"About Deploying Customizations Using the Server Manager Command-Line Interface"
This topic is part of "Options for Deploying Customizations Using Siebel ADM".
Deploying ADM customizations using the Siebel application ADM GUI is available to database types only. This deployment method requires both the source and target environment to be online and in communication using HTTP. You run this deployment from the source environment.All ADM database types are available for migration using this method. However, the deployment is limited to just the copy operation of these run-time customizations. For more information about this deployment method, see "Deploying an ADM Session or Export File".
Deploying ADM customizations using export files is available to certain database types only. This deployment method creates XML export files using the Siebel application ADM GUI. The XML files are exported from the source environment and imported into the target environment at the ADM GUI. For more information about this deployment method, see "Deploying an ADM Session or Export File".
Deploying ADM customizations using the Server Manager (srvrmgr) command-line interface is available to certain database types only. This deployment method migrates export files created from the source environment, using the Siebel application ADM GUI, and migrates the export files using the Server Manager command-line interface and a preconfigured workflow process. For more information about this deployment method, see "Deploying an ADM Session or Export File".
