| Siebel CRM Application Deployment Manager Guide Siebel Innovation Pack 2015 E24721-01 |
![]() Previous |
![]() Next |
View PDF |
The proper functionality of Siebel Application Deployment Manager (ADM) depends on run-time requirements for the following items:
This topic is part of "Siebel ADM Run-Time Requirements".
Specific server components must be enabled and online to run an Application Deployment Manager (ADM) deployment. See Table 3-1 for the server component groups that must be enabled to run an ADM deployment.
Table 3-1 Server Component Requirements for ADM Deployment
| Component Group | Export | Deploy from File | HTTP Deployment |
Auxiliary System Management (alias SystemAux) |
Required |
Required |
Required |
Enterprise Application Integration (alias EAI) |
Optional |
Optional |
Required |
System Management (alias System) |
Required |
Required |
Required |
Workflow Management (alias Workflow) |
Optional |
Optional |
Required |
If certain Siebel objects are modified or removed, then Application Deployment Manager (ADM) might fail to function properly. The following Siebel objects must not be modified or removed during the deployment:
Do not modify or remove the following workflows:
ADM Deployment
ADM Restore
UDA Acknowledgement
UDA Batch Deployment
UDA Batch Import (Exception: before using this workflow to import customizations from the command line, you must update the Import File Directory property for this workflow.
UDA Data Query
UDA Deployment
UDA Environment Verification
UDA HTTP Transport
UDA Import File
UDA Target Workflow
Do not modify or remove the following business services:
ADM JDB Service
XML Converter
ADM Service
ADM Status Report Business Service
Access Controlled BS Cache Clear Service
Access Controlled Task Cache Clear Service
