Siebel Applications Administration Guide > Accounts > Synchronizing Account Information with External ApplicationsThe Application Services Interface (ASI) feature allows you to synchronize the account data between a Siebel application and an external application in real time. This feature enables you to maintain consistent account information across your enterprise, and to eliminate manual entry of data in multiple applications. If your Siebel administrator has set up real-time account integration between a Siebel application and another application, then you can use the Update External System command to send new and modified account information from the Siebel application to the other application in real time. For more information about ASI, see Siebel Application Services Interface Reference and Integration Using ASIs. If an account has associated contacts, then you must synchronize the contacts with the external application separately. For more information, see Synchronizing Contact Information with External Applications. To synchronize account information with an external application
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
