| Siebel Applications Administration Guide > Activities >  Working with Others' Activities (End User)
 The following procedure describes how to work with another user's activity records, if that user has granted you permission to do so. For information about how to grant permission for another user to work with your activity records, see information about granting access to your calendar in Siebel Fundamentals. To work with another user's activity records
Navigate to the Activities screen, then the Others' Activities List view.
In the drop-down list in the header, select the user whose activities you want to work with, and click Go.
If you have add-and-modify access to the records, then the icon to create activities is available, and you can work with these records as your own. If you have not been granted permission to make changes, then this icon is inactive. |
