Siebel Applications Administration Guide > Adobe Forms Integration > Generating an XML Schema for Forms IntegrationComplete the steps in the following procedure to generate the XML schema. For more information, see XML Reference: Siebel Enterprise Application Integration. This task is a step in Process of Setting Up Adobe Forms Integration. To generate the schema for the forms integration object
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
