Siebel Applications Administration Guide > Adobe Forms Integration > Preparing for Adobe Forms Integration SetupYou must perform the following steps before you can set up and use Adobe forms integration with a Siebel application. After you verify that the tasks are complete, you can begin the forms integration tasks. For more information about Adobe software version requirements for outbound forms integration, see Siebel System Requirements and Supported Platforms on Oracle Technology Network. NOTE: For Siebel CRM product releases 8.1.1.9 and later and for 8.2.2.2 and later, the system requirements and supported platform certifications are available from the Certifications tab on My Oracle Support. For information about Certifications, see article 1492194.1 (Article ID) on My Oracle Support. This task is a step in Process of Setting Up Adobe Forms Integration. Preparing the Setup for Adobe Forms Integration
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
