Siebel Applications Administration Guide > Adobe Forms Integration > Enabling Forms Integration for Additional Applets Using Siebel ToolsBy default, Adobe forms integration is enabled on the following applets:
You can also generate forms that are based on other business objects, such as opportunities. Administrators can use Siebel Tools to add Adobe forms integration functionality to other applets in Siebel Business Applications. For more information, see Siebel Tools Online Help and Using Siebel Tools. This task is a step in Process of Setting Up Adobe Forms Integration. To add forms integration functionality to application applets |
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
