Siebel Applications Administration Guide > Siebel Audit Trail > Customizing Siebel Audit TrailSiebel Audit Trail is a closed set of functionality that is designed to be used as delivered. It is one of the very few areas of the Siebel application that is not suitable for additional customization and configuration by integrators or customers. Audit trail data is stored is an internal format and is only accessible through the virtual business component. NOTE: Additional custom columns and trigger points for inserting audit trail data are not supported. |
Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
