Siebel Applications Administration Guide > Getting Started >
About License Keys
As of Siebel Innovation Pack 2014, you do not have to enter the license keys for Siebel CRM base applications. The license keys are provided in the seed data that is imported into a new Siebel database. For more information, see the topic about installing the Siebel Database in Siebel Installation Guide for the operating system you are using. The license keys are also part of the seed data that is imported into an existing database as part of the Incremental Repository Merge or database upgrade operations. For more information about performing these operations, see Siebel Database Upgrade Guide.
