Siebel Applications Administration Guide > Households > Synchronizing Household Information with External ApplicationsThe Application Services Interface (ASI) feature allows you to synchronize the household data between a Siebel application and an external application in real time. This feature enables you to maintain consistent household information across your enterprise, and to eliminate manual entry of data in multiple applications. If your Siebel administrator has set up real-time household integration between a Siebel application and another application, then you can use the Update External System command to send new and modified household information from the Siebel application to the other application in real time. For more information about ASI, see Siebel Application Services Interface Reference and Integration Using ASIs. This task is a step in Process of Managing Households. To synchronize household information with an external application
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
