| Siebel Applications Administration Guide > Managing Portfolios > Process of Analyzing B, C, and D Accounts > Entering Details of the Account
 You must enter details for each of your A, B, C, and D accounts. This task is a step in Process of Analyzing the A Accounts and Process of Analyzing B, C, and D Accounts. To enter details of a portfolio account
Navigate to the Accounts screen, then Portfolio Management Process view.
Drill down on the Portfolio Name field of the portfolio plan record.
Navigate to the appropriate account planning view.
Complete the necessary fields in the account planning view.
Some fields are described in the following table.
    | Account | Displays the name of the account. |
    | Actual Account Type | Select the type of account. |
    | Importance To You Breakpoint | (A Account only) Displays the value that distinguishes the accounts on the top side of the segmentation map and the bottom side of the segmentation map. |
    | Importance To Customer Breakpoint | (A Account only) Displays the value that distinguishes the accounts on the left side of the segmentation map and the right side of the segmentation map. |
    | Account Team | Displays the team responsible for the account. |  |
