Siebel Applications Administration Guide > Managing Portfolios > Process of Analyzing B, C, and D Accounts >
Analyzing Selected Units
After you select the business units and service units that you want to work with, you must analyze these units, and add the business driver, initiative, and critical success factor information. This task is a step in Process of Analyzing the A Accounts. To analyze selected business units and service units
- Navigate to the Accounts screen, then the Portfolio Management Process view.
- Drill down on the Portfolio Name field of the portfolio plan record.
- Navigate to the A Account Planning view, then the Selected Unit Analysis view.
You can review the fields in the Selected Unit Analysis view. For more information about the fields, see Assessing Business Units and Service Units.
- To add information about the business drivers for the BU/SU, create a new record in the Drivers list, and type the driver information in the Driver field.
- To add information about the business initiatives for a driver, select the driver, create a new record in the Business Initiatives list, and complete the necessary fields.
Some fields are described in the following table.
Business Initiatives |
Type the business initiative associated with the business unit or service unit. |
Critical Success Factor |
Type the critical success factor associated with the business initiative. |
