| Bookshelf Home | Contents | Index | PDF |    |
| Siebel Applications Administration Guide > References > Adding Profile Information to a ReferenceThe Profile view allows you to update the account with information about the assets owned by the account, and information about the service profile. The service profile is a list of all external products the account is using in its operating environment. For example, if your company sells application software, then you might add information about the server hardware and end-user operating system used in conjunction with your products. This task is a step in Process of Managing Accounts and References. To add profile information to a reference
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
