| Siebel Applications Administration Guide > References >  Associating a Contact with a Reference
 You can designate a specific contact within a referenceable account. This contact can provide you with reference information or the individual can be the point-of-contact for activities associated with the account. This task is a step in Process of Managing Accounts and References. To associate a contact with a reference
Navigate to the References screen, then the Reference List view.
Drill down on the Stage field of a reference record.
Navigate to the Contacts view.
In the Contacts list, perform one of the following steps:
Add an existing contact, select the contact from the Add Contacts dialog box, and click OK.
Create a new record in the Contacts list, and complete the necessary fields for the contact.
