Siebel Applications Administration Guide > Signature Capture >
Registering the OCX File
The cicink.ocx file contains the Ink Capture and Display ActiveX control. You must extract the cicink.ocx file from the iTools.cab file, then register the file on the host for Siebel Tools. This task is a step in Roadmap for Implementing Signature Capture. To register the OCX file
- Check that the iTools.cab file is present on the host for Siebel Tools.
- If iTools.cab is not present, then copy the file to the host from one of the following locations:
- drive_letter:\SWEApp\PUBLIC\language\build_number\applets. For example, D:\SWEApp\PUBLIC\enu\19213\applets.
- drive_letter:\siebsrvr\WEBMASTER\build_number\applets. For example, D:\siebsrvr\WEBMASTER\19213\applets.
- drive_letter:\client\PUBLIC\language\build_number\APPLETS. For example, D:\client\PUBLIC\enu\19213\APPLETS.
- Decompress the iTools.cab file, then extract the cicink.ocx file from the file.
- In a Windows command prompt, change directory to the directory where the cicink.ocx file is located.
- To register the file, run the following command:
regsvr32 cicink.ocx
