Siebel Applications Administration Guide > Signature Capture > Process of Creating an Applet for Signature Capture >
Creating a Form Applet
You must create a form applet into which you can insert the controls to handle the capture and storage of the signature. This task is a step in Process of Creating an Applet for Signature Capture. To create a new form applet
- In Siebel Tools, select File, New Object, and then Form Applet.
For more information about how to create applets and form applets, see Using Siebel Tools and Configuring Siebel Business Applications.
- In the wizard, select the project, name, and business component for the applet.
- Select the Use Grid Layout check box.
- Select Edit Mode for the applet.
- Select the fields and controls that you want on the applet.
NOTE: Do not select the AASignature control at this point.
- Click Finish to create the applet.
