Siebel Applications Administration Guide > Global Target List Management > About Configuring Target Lists >
Configuring Global Target List Management to Create Activities Asynchronously
In the preconfigured Siebel application, when the Create Activities for List command (Create Activity button) is invoked, activities are created synchronously. If your users typically create activities for long lists, then the response time for synchronous creation can be slow. To resolve this issue, you can configure the Siebel application to create the activities asynchronously. To configure asynchronous activity creation from target lists
- In Siebel Tools, change the On Close Invoke Parent Method user property for the SLM Create Activity Popup applet from the default value of ContinueCreateActivity to ContinueCreateActAsync.
- Activate the SLM Create Activity From List workflow.
For general information about Siebel workflows, see Siebel Business Process Framework: Workflow Guide.
