| Bookshelf Home | Contents | Index | PDF |    |
| Siebel Applications Administration Guide > Web Services > Getting the Data for a Mail Merge from the Siebel DatabaseYou can use the Word Web service to get contact information for a mail merge from your Siebel database. You perform the following actions to create the query to run:
 When you run the query, the output is saved in a local area as the data source for your mail merge. This task is a step in Process of Using Word Web Service to Perform a Mail Merge. To get contact data from the Siebel database
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
