Siebel Applications Administration Guide > Web Services >
Requirements for Connecting Templates to Siebel EAI
Before you can connect an Excel or Word template to the Siebel Enterprise Application Integration (EAI) component, you must make sure that the following conditions are met:
  • Siebel Enterprise Server is running.
  • Siebel Server or Siebel Gateway Server is running.
  • Siebel EAI component group is enabled.
  • Siebel Workflow Management component group is enabled.
  • The Siebel Application Object Manager for the Siebel application with which you want to use the Excel or Word template is running.
  • Seed data for inbound Web services is available.
  • The Excel or Word template is available.
Siebel Applications Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
