| Bookshelf Home | Contents | Index | PDF |    |
| Siebel Applications Administration Guide > Working with Lists of Values > Modifying a List of ValuesCAUTION: Use caution when modifying lists of values that are part of the seed data. Modifying some list-of-values fields that are used programmatically by the Siebel application can adversely impact standard Siebel functionality. However, you can modify the Display Value field without affecting standard Siebel functionality both when the list is a multilingual list of values (MLOV) and when it is a standard list of values. Modifying some lists of values can adversely impact standard Siebel functionality:
 NOTE: Modifying a Display Value field does not automatically update records that have been populated with the old value. For example, if you change Ms. to Miz in the Display Value field, then Miz appears in the drop-down list, but all contact records that were previously entered with Ms. in the Personal Title field still have Ms. in the Personal Title field. To modify a value in a drop-down list, you must know its display value and type. You can find out the type by querying the list-of-values list for a specific display value. For example, if you must make a change to the value 1-ASAP in the Priority drop-down list in the Activities screen, then you can do so using the following steps. For more information about multilingual lists of values (MLOVs), see Configuring Siebel Business Applications. To modify an item in a list of values
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
