| Bookshelf Home | Contents | Index | PDF |    |
| Siebel Applications Administration Guide > Working with Lists of Values > Constrained Lists of ValuesSome drop-down lists are set up to display a subset of values that are based on a value set in another drop-down list. For example, if you have two fields for Service Request, Area and Subarea, then the values shown in the Area drop-down list might include Network and Upgrade. If the user selects Network, then that user might see a drop-down list for Subarea that includes Ethernet Card and 3rd Party Software. If the user selects Upgrade for the Area, then that user might see CD-ROM, Disk Drive, Memory, and Operating System in the Subarea. This type of filtering is a constrained drop-down list. In such a case, the lists of values are configured to depend on each other. In this example, the Area drop-down list is the parent, and the Subarea drop-down list is the child. For information about constraining both static drop-down lists (maintained through lists of values) and dynamic lists, see Configuring Siebel Business Applications. Constrained drop-down lists (or lists of values) must first be set up through Siebel Tools. After they are configured through Siebel Tools, specific values in lists can be made hierarchically dependent through the List of Values view. You use the Parent LIC field in the list-of-values record to specify the values that appear when a value is selected in the parent drop-down list. For example, the LOV Type SR_AREA is used by both the Area and Subarea drop-down lists in a Service Request. The values that appear in the Area drop-down list are constrained to those that have a Parent LIC value of External. The values that appear in the Subarea drop-down list are constrained to those that have a Parent LIC value that matches the user's selection for the Area. For example, if the user selects Network in the Area drop-down, then only those values that have the Parent LIC field set to Network appear in the Subarea drop-down list, while if the user selects Upgrade in the Area drop-down, then only those values that have the Parent LIC field set to Upgrade appear in the Subarea drop-down list. If you want to change the parent Area of a Subarea list item, then you must modify the Parent LIC field of the Subarea list item. Similarly, to add a new Subarea list item, you must create a new record, setting the list-of-values type to SR_AREA and the Display Value, Language Independent Code, and Language as described in Adding a New Value to an Existing List of Values. Then you set the Parent LIC field to the appropriate parent area. By contrast, to add a new item to the Area drop-down list, you follow the same steps, but specify that the Parent LIC field have the value External. NOTE: The usage of the External value to identify items in the parent drop-down list is specific to this example. To determine this value for any pair of constrained drop-down lists, reference the underlying configuration in the Tools Repository. SR_AREA LOV is used by the SR_TYPE, Area, and Sub Area LOVs in a Parent-Child-Grandchild hierarchy. SR_AREA LOV configuration is different when compared with other LOVs. While creating SR_AREA LOV values make sure that:
 NOTE: In the example using the Area and Subarea drop-down lists, both parent and child lists of values have the same list-of-values type. This condition is not required, but it has the advantage of avoiding EIM unique key violation errors. These errors can occur when constraining drop-down lists using Siebel Tools, when the parent and child lists of values contain different list-of-values types. If you plan to use Siebel EIM to exchange list-of-values data, then consider constraining drop-down lists by configuring them so that the parent and child lists of values have the same list-of-values type. |
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
