| Siebel CRM Assignment Manager Administration Guide Siebel Innovation Pack 2015 E24725-01 |
![]() Previous |
![]() Next |
View PDF |
This topic provides a high-level overview for planning your Siebel Assignment Manager deployment. Investing appropriate time in analyzing the incoming data and loading data appropriately for the first time can reduce performance and other problems moving forward.
Use the following points to help plan your deployment:
Develop a migration path from an external source to Siebel Assignment Manager and, if using territory management, then also carefully plan import of external alignment rules.
Note: This task is particularly important if your implementation has mobile users. |
Use assignment rule groups to manage large numbers of rules.
Use rule sequencing to prioritize rules by order of importance.
This feature can be helpful for Assignment Manager newly imported from an external system, because you can execute batch assignment against just the newly imported rules.
Use server key mappings to run multiple instances of Assignment Manager with different groups of rules loaded.
Create custom criteria for date fields (called date criteria).
Date criteria allow you to specify additional selectivity while assigning particular objects, such as creation date, expiration date, and so on.
If your assignment rules are static (that is, less frequently changing), then consider using dynamic assignment instead of batch assignment.
Identify opportunities where you can reduce assignment rules, such as:
Reusing assignment rules across objects
Using skills
Setting up dynamic candidates
For more information about how to reduce assignment rules, see "Planning Optimal Assignment Rules".
