Siebel Automotive Guide > Managing End of Lease and Remarketing Activities > Setup Tasks for End of Lease and Remarketing >
Configuring the Siebel Server to Run the Scheduling Job
When the automotive company schedules inspections with dealers and third-party inspection agencies, all the inspections are listed in the Financial Accounts screen, Vehicle Batch Order Inspection List view.
You can trigger the batch run to schedule all the listed inspections manually, as described in Scheduling Inspection and Turn-In Appointments. However, it is recommended that you configure the Siebel server to run the scheduling job regularly, for example, every night. You can do this by setting up a component request. For more information on scheduling jobs, see Siebel Applications Administration Guide.
To set up a component request to run the batch scheduling job
  1. Navigate to the Administration - Server Configuration screen, Enterprises, then Component Definitions view.
  2. In the Component Request form, Query for the component Workflow Process Batch Manager.
  3. If the component does not already exist, create it by adding new record to the Component Definitions list and completing the necessary fields.
    Some fields are described in the following table:
    Field
    Description
    Component
    Enter Workflow Process Batch Manager
    Alias
    WfProcBatchMgr
    Component Type
    Select Workflow Process Manager with Batch as the runtime mode.
    Component Group
    Workflow Management
  4. Navigate to the Administration - Server screen then the Jobs view.
  5. Add a new record to the Jobs list and complete the necessary fields.
    Field
    Description
    Component/Job
    Select Workflow Process Batch Manger.
    Repeating?
    Select this check box.
    Repeating Info
    In the Repeating Info form, enter values in the Repeat Interval, Repeat Unit and Scheduled Start fields to determine when the job runs.
  6. In the Job Parameters list, add new records with the following values in the fields.
    Name Field
    Value Field
    Search Specification
    [Account Type] = 'Asset Finance' AND [Account Status] = 'Open' AND ([Maturity Date Diff] = 180 OR [Maturity Date Diff] = 90 OR [Maturity Date Diff] = 30)
    Workflow Process Name
    eAuto CF Lease End Communication Workflow
    User Name
    Enter the user name.
    Password
    Enter the password.
  7. Submit the job.
    The status becomes Active, and the job runs at the repeat interval specified.
Siebel Automotive Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
