Siebel Business Process Framework: Workflow Guide > Adding Workflow Process Steps > Overview of Workflow Process Steps > Naming a Workflow Process Step or a Process PropertyThe name that you use for a workflow process step or process property must be unique in the workflow process. You cannot use some symbols, such as the period (.), in the name of a process property. If you add a new step, then Siebel Tools populates the Name property of the step with a name and number combination that you can change. The step or connector type determines this name. For example: The number differentiates instances of the same type of step or connector that the workflow process contains. For example, Business Service 0 and Business Service 1. You can change this name. Siebel Workflow uses the following name for this number and stores it as part of the name: How Siebel Tools Assigns Sequence Numbers to Workflow Process StepsIf you add a new step to a workflow process, and if this workflow process already contains an instances of this step type, and if:
For example, assume a workflow process includes the following business service steps: If you delete Business Service 1 and Business Service 2, and if you then add a business service step, then Siebel Tools names this new step Business Service 1. Siebel Tools uses the same numbering configuration for connectors. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
