Siebel Business Process Framework: Workflow Guide > Administering, Testing, and Migrating Workflow Policies > Administering Workflow Policies > Confirming Workflow Policies InstallationIn this topic, you make sure workflow policies are installed correctly. You install the Workflow Policies module when you install the Siebel Server and the Siebel client. You use your license key to activate Workflow Policies. This topic describes only how to make sure Workflow Policies is correctly installed. For information about the installation process, see the installation guide for the operating system you are using. To use Workflow Policies, make sure server components, including Workflow Management, Siebel Tools, and the Siebel client, are installed. Confirming the Repository Setting for Workflow PoliciesSiebel CRM uses the cfg file in the Siebel client to configure the Workflow Policies module. You must make sure the DockRepositoryName parameter of this cfg file references the correct repository name. Confirming Siebel Workflow is Set Up for Workflow PoliciesYou must make sure that your license key includes Siebel Workflow. You must also make sure you installed the Siebel Server correctly. Siebel Workflow runs as a server component on the Siebel Server. To confirm Siebel Workflow is set up for workflow policies
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
