Siebel Business Process Framework: Workflow Guide > Defining Custom Workflow Policies > Defining Conditions for a Workflow Policy > How Siebel CRM Interprets a Field That Is Not KnownIf a field value is not known rather than having no value, then Siebel CRM interprets it as null. For example, assume a condition includes the following logic: FIeldA IS UPDATED In this situation, if FieldB is null, then the following condition is false: Siebel CRM interprets a Null field value as not known. It assumes this field could be set to anything, including Y. Siebel CRM cannot conclude that the field is definitely not set to Y, so it returns false and does not run the Workflow Monitor Agent. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
