Siebel Business Process Framework: Workflow Guide > Defining Custom Workflow Policies > Process of Planning a Workflow Policy > Creating a Plan for the Workflow PolicyThis task is a step in Process of Planning a Workflow Policy. Many of the workflow policy objects and workflow policy programs that your workflow policies require come predefined. You can use Siebel Tools to modify workflow policy programs, define more workflow policy objects, or to make more workflow policy columns available for monitoring. The planning phase is an appropriate time to review business process activities for your company. You must identify the work that a workflow policy can automate. For more information, see the following topics: Developing Workflow Policies in Small GroupsIt is recommended that you define and implement a small group of workflow policies at a time. After you successfully implement the group, you can proceed to another small group of policies in a systematic manner. If the business environment requires you to change your plan, then you can assign a workflow policy to a different group. For more information, see Moving a Workflow Policy to a Different Group. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
