Siebel Business Process Framework: Workflow Guide > Defining Custom Workflow Policies > Process of Planning a Workflow Policy > Creating a Plan for the Test and Migration StrategyThis task is a step in Process of Planning a Workflow Policy. You must make sure that any new workflow policy that you create works properly in a test environment. The test environment can include a sample Siebel database and test data. Testing a new workflow policy, workflow policy condition, and workflow policy action makes sure that the policy you release to the production environment runs correctly and does not cause a conflict with another workflow policy. Guidelines for Creating a Plan for the Test and Migration StrategyIf you create a plan for the test and migration strategy, then it is recommended that you use the following guidelines:
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
