Siebel Business Process Framework: Workflow Guide > Options for Configuring a Workflow Process > Configuring a Workflow Process for a Multilingual EnvironmentThis topic describes how to define a workflow process to function correctly in a multilingual environment. It includes the following topics:
To configure a workflow process to work correctly in a language other than the base language, you must make sure the database that your configuration uses can handle Multilingual Lists Of Values (MLOV) for the type of language that the production environment uses. For example, if you must modify a workflow to use FRA, and if the base language is ENU, then make sure that List of Values entries exist for the FRA language type. For more information, see Siebel Global Deployment Guide. To configure a workflow process for a multilingual environment
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
